I have an electric towel rail in the bathroom (zone 2) but it needs connecting. There is an FCU outside the bathroom ready, directly behind where the towel rail is situated but the flex from the rail needs to run to the FCU. Is it permissable to run flex just through the wall or is a flex outlet plate needed? If the latter, is a back box needed as this will require chopping out a hole in the tiles to accommodate it unless I use a surface box.
If a plate is needed, can the flex run through the wall and fix a blanking plate over the hole without a back box?
