Connecting Grohe shower valve
1 Aug 2006
Coventry
The valve has 15mm female points to connect H & C and outlet. I need to connect the feed pipes and thought there might be a compession fitting to do this. I don't feel that screwing in a compression elbow or straight coupler would be watertight.
When an elbow is turned in fully, it points the wrong way (180 degrees out!) and is going when it should be coming out of the stud wall. I only have 4.5cm of room although I could drill through the stud and then bend out then.
There must be some-one who has fitted so many of these they can do it in their sleep. (I am still in nightmare mode!)
