Connecting microbore to manifolds
23 Jun 2006
I want to relocate a radiator on my microbore system. I know that I can get the pipe from the local plumbers merchants, but my manifolds have a screw fitting on them. Do I need ton flare the pipes with a tool so that the threaded nuts hold the pipe into the manifold?
The " screw fittings" are compression fittings. You don't flare the pipes but you will need new olives.
cheers
