With all the rain we've had i noticed that one of the downpipes off the roof was over flowing where it goes into the ground.
Removing the down pipe i find that its connected straight into an earthenware elbow which cracked at some point in the past and been badly repaired with cement.
The elbow and the under ground pipe that it connects to were both full of soil so i removed the elbow, cleared the horizontal pipe as far as i could reach and then was able to clear the remaining soil by washing the pipe out with the jet of water from a hosepipe until the drain was running clear and i could hear the water running through at the next drain down the line.
I temporally replaced the elbow and sealed the join with plumbers mait, but i obviously need to do a permanent repair.
I need to replace the earthenware elbow and connect to the existing earthenware under ground pipe.
Stupidly, i didn't measure the bore of the pipe.
I'd like to replace the old cracked elbow with modern plastic, but can anyone advise me what the pipe bore is likely to be and what i should be using to make the connection? Is there a push fit adaptor that i can buy?
