I am replacing several old storage heaters and switch boxes.The origional flex from switch to heater is quite heavy and measures approx.10 mm radius.My electrical supplier has supplied flex which is approx 7mm ,I'm not sure if this is sufficient for a 3.4 kw heater. Also is a 20amp double pole switch sufficient? The heaters are all on seperate circuits on economy seven.
Many Thanks.
Many Thanks.
