- Joined
- 11 Jan 2004
- Messages
- 170
- Reaction score
- 4
- Country
I have a problem with condensation in my plastic shed that apparently is common and want to use a vent to do away with this by circulating the air. I have seen solar powered vents for sale that obviously rely on sunlight. The shed is at the back of my workshop and therefore unlikely to be hit directly by the sun. I could presumably either get around this by using a small solar panel situated around the corner and connecting it to the vent or connecting it to my supply in my workshop using one of those low voltage adaptors with the volt selection switch(normally 3-12 volts). If I go for the latter option and it is on permanently is it likely to be very cheap to run on low voltage if the motor itself is very small( normally can be run by 2 x AA batteries when dark). Any advice welcome. Thanks. Jim
