I am trying to plan the plumbing for my new house.
One of the bathrooms will be on the ground floor which will have a solid concrete floor. I need to connect the bath waste to the soil pipe but obviously don't have a huge depth to do it in. The distance between the bath waste and the soil pipe won't be massive. If I use a HepVo trap on the bath and then connect to a boss on the soil pipe at the lowest possible level above the floor (i.e. with the base of the boss sitting on the concrete) am I likely to have any problems?
The bath might be something like a Kaldewei Saniform which appears to have a gap of about 125-145mm between the bottom of the bath outlet and the floor. I can get about another 30mm by not laying any flooring round the soil pipe so that would give me about 155 - 175mm between the bottom of the boss and the bottom of the bath outlet. Into that space I need to get the HepVo and presumably a banjo for the overflow and maybe 5mm vertical drop for the slope.
Any problems with my plan? (I know that I need to have at least 450mm from where the waste pipe joins the stack to the bottom of the rest bend).
Is there any advantage in using a shallow P trap before the HepVo to connect the overflow rather than using a banjo?
While I'm on, I need to join the shower waste at probably the same level. Am I right in thinking that I can join two waste pipes to the soil pipe at the same level at a 90 degree angle but not directly opposite each other (i.e. 180 degrees)?
Hope this makes sense.
