connecting to 4 inch pot waste
16 Jul 2009
Hull
hey what fitting do I need to connector to a 4inch pot waste. Is it a drain connector?
thinking the fined end will fit in to the 4inch clay pipe ? Its above ground
Is that what these drain connector fittings in the picture above are for?
I used one to connect into 4" asbestos, worked well enough
I suspect 4"clay would not be much different.
By the way you can edit your posts so it doesn't look like you're talking to yourself.
