Connecting to a mono block mixer
H
HiZ
I have just received a monoblock Ideal Standard tap for my basin and the unit comes complete with two lengths of 10mm? coper which screws to the underside of the block.
Are there special push fit connections to allow easy connectivity of these as they are very close. Are there figure of 8 shaped connector bundles to allow easy connection?
If not I guess i would stagger the lengths i chop them too. I can't seem to find puch fit 15mm->10mm flexi tails. I can't be the first to plumb in a monoblock tap to some 15mm!
Ther`e close to start with .......but when fitted you ease them apart to get @ them .....then I`d use compression fittings
Flexi tap connectors aren't intended for monoblocs which already have hand-bendable copper tails.
