A push-fit coupler that connects to the 15mm copper tail pipes on my Kitchen tap is leaking. I tried a new pushfit coupler but no luck and on closer inspection noticed that the tail pipe has been crushed so is not perfectly round. The problem is worse higher up the pipe (closer to the tap), so cutting won't help.
Is there any connection that can be made to a mis-shapen pipe? I'm pretty sure compression won't work - so basically I'm wondering whether a soldered joint (something I've never used before) will work? If not how are these tail pipes typically connected to the tap? Are they replaceable?
