Hey I need to connect to an incoming water main under the kitchen floor in a house. The supply turns off outside the house but it passes a bit so I can't solder a fitting on to the pipe to move it I really need to use a compression fitting. Is this acceptable the fitting will on completion of the job be underneath a insulation/ screed floor as the floor is getting replaced.
