Connecting To Old 3/4" Copper Pipe That's Smaller Than Usual
aaf
19 Oct 2005
I'm trying to connect 3/4" copper to 22mm copper in an old house. However it appears that the 3/4" is actually slightly smaller (measured at 21.1mm) than it normally is. This means I've been unable to use the special 3/4 to 22mm compression fittings as the olive is just too loose. Similarly I have a 3/4 to 22mm solder fitting, but that's too loose for the solder as well.
Anybody come across this situation and have any tricks?
Thanks!
Hi, Thanks for the response, but I've tried that. As I explained the 3/4" pipe is smaller than normal and the 3/4" olives are too loose.
Usually a 3/4" pipe is about 21.5mm (external), mine are 21.1mm.
I'm thinking about swaging it. But I'd have to buy a swaging tool, heat treat the pipe to make it less hard and do it all in-situ. Bit of a pain.
if its brass olives your using sometimes they wont compress enough it could be worth trying 3/4 copper olives. even with your pipe being smaller
