- Joined
- 16 Feb 2021
- Messages
- 8
- Reaction score
- 0
- Country
Hi All
I'm hoping for a little help.
I posted on the Texecom Support forum and it was promptly removed!
When I took this building on there was a Texecom Premier Elite 24 installed but was not being used. I have managed to commission the alarm and it appears to be working great, I have also upgraded it with The Texecom Connect Unit with Wifi and I can connect to the alarm using the app.
I still need to tweak a few things in the config and was wondering how easy it would be for me to do this using Wintex, I have tried using the menu system via the RKP but find this awkward, time confusing and I easily get lost/confused as to where I actually am and have to cancel out and start again, the information I have seen online makes the software look like it is A LOT easier.
I am not an alarm engineer and cannot afford to pay one, hence I got it all working again myself, lets say I am a competent enthusiast.
I have installed the software and just need to know what I need to do next, where do I put the IP of the Panel..... or is that not how it works. is it simply a case of ensuring the laptop is on the same subnet, click "Connect" and enter the App code when requested?
I'm trying to get everything sorted in my head before going to site to do the work, at least it is warm here
Also, when using the app I Sync'd with the panel and the additional user I added appeared but I was unable to select to allow then to use the app, when I logged out and in as an engineer the user had disappeared, I'm sure i'm doing something wrong and the panel/app is working as expected.
Kind regards
Kind regards
