Hi, I hope someone out there can advise me on what (if any) problems I could cause myself by connecting my conservatory underfloor heating in the following way;
For access and clearance, it would suit me to tee off the hot water supply and return for the UFH in the pipes before (yes BEFORE) the main system circulation pump and Y plan zone valve.
In the main central heating system (as fitted) the boiler is situated remotely in a front bedroom. It then has a long copper pipe (25mm diameter) run across the loft, to a back bedroom. This is where the main circulation pump, Y plan zone valve, hot water tank and electrical controls are fitted in a small cupboard.
There is not much room in the cupboard (or even under the floor in there) to tee off the UFH in the pipes after the pump and zone valve.
However there is loads of room to put take off tee's in the pipes in the loft between the boiler and that cupboard.
My UFH system has its own self contained controls, mixing valve and circulation pump set up.
I imagine this way of plumbing in, may mean that UFH takes priority over the rest of the system for hot water flow (which may be a benefit as I think the conservatory will require more heat than the rest of the house). But is there anything else I need to consider?
Thank you all for your thoughts!
