Connection for new toilet
26 Sep 2010
Middlesex
Hello all,
I need a bit of advice. I am thinking of changing my old style of toilet for a newer type. However, I am not sure what kind of connectors I need to connect the new toilet to the existing cast iron soil pipe. I have uploaded a picture of the existing connection so please click the link below to view it.
Many thanks in advance of your help. :D
//www.diynot.com/network/LesJ33/albums/
cut the flange off and fit one of these.
Thanks Seco. I’d seen those drain connectors in the Hardware store, just needed to be sure that they were the right thing. I have a few questions though, if that’s ok?
Are those drain connectors a standard size and fit? It’s just I’ve seen them in white, black and grey. Is there a preferred method to fitting them (i.e. finned end into the cast 1st), as I’ve heard about people experiencing leaks once they are connected? Or would this just be due to a poor connection?
What’s the best way to cut the flange, a 230mm angle grinder with a metal cutting blade or a hacksaw? I don’t want to cause any unnecessary damage to the cast?
Also, am I right in thinking that once I’ve cut the flange off, all I should be left with is the 5 or so inches of cast that is protruding from the wall?
Thanks again
Could be a 3 1/2 inch inside diameter iron pipe . Multiquik needed rather than those rigid plastic connectors :idea:
