Hi
I have a concealed cistern behind a fitted unit that connects to the bowl via an L shaped pipe. It has started leaking at the joint to the toilet bowl. I note that the cistern and bowl are not aligned properly. The L shaped joint looks as though it was cut short by the plumber to fit it and has now come loose. It still leaks leaks when I try to reconnect it. Any idea how to reconnect this badly aligned set up without a leak?
