connection of shower cubicle waste pipe
13 Jan 2009
Devon
I am installing an ensuite facility and have to decide on the waste connection. The easiest route is to tee into the adjacent bathroom waste under the bath. I thought to connect with a 45 degree tee into the bath waste pipe. Will there be a problem of flow back into the shower which will be about 7 metres of pipe run away? Is there such a thing as a non return valve for waste water pipes?
yes you can get NR valves for waste pipe, however they are supposed to be easily accessible as they can clog easily.
McAlpine do them iirc.
