About to embark on converting my garage with it partly to be used as a utility and therefore need to have a plastic waste outlet for washing machine. I have a clay waste pipe running right outside the wall on which the washing machine will be fitted so it would seem I am lucky. However the waste pipe runs with a foot gap between it and the wall, with the gas pipe recently laid in this gap by national grid.
From what I have read it seems the best option is to cut in to the clay and run a new manhole in with adapters but I think the gas line may be in the way based on circumference of manhole.
Is there a simpler small diameter manhole or similar fitting to allow connection of plastic washing machine waste into clay?
Is there a way of branching into a existing manhole type fitting that I have fitted further up the line, it isn't a plastic thing, but brick built sided, kinda glazed clay job at the bottom? Sorry rubbish description.
As an alternative would BCO be happy to see me run the waste pipe along the outside of the wall back along to the manhole where the washing machine used to be or is he going to laugh at it as though it's some kinda bodge?
