Hi all, my first post!
I've just had a conservatory built by a local respected company. I watched the process throughout (not minute by minute though,lol) and took photos of key stages.
I would like peoples opinions of the following bits I'm concerned about.
1/ The foundation is 1 metre deep, going through 2 of the foundation strips at about 45 degrees is a pipe connected to a downpipe which I believe must go to a garden soakaway. This has just been surrounded by the concrete of the foundation, no lintel (I asked the groundwork chaps about this). There is also an armoured cable supplying my garage which again is just buried in the concrete.
2/ One side of the dwarf wall of the conservatory is built flush with one foundation strip, ie, the dwarf wall is not centered on the 450 wide foundation.
3/ The dampcourse consists of a painted on bitumous product which was applied to the slab and then covered by approx 75mm of finishing screed mix.
4/ there is no insulation in the base slab.
5/ the existing weep vents above the patio door lintel have just been plastered over, there is no cavity tray fitted above the conservatory roof (although, there is only 3 courses of bricks between the conservatory flat roof and the undrside of the next opening above it)
All opinions and advice welcomed.
