I have a large conservatory about to be constructed. I discussed with the builder the issue of overlapping the existing DPC with the 1200 gauge DPM. He says that to do so properly along the 6 meter length of wall will involve cutting out the cement above the DPC which will, almost certainly, damage it. I agree with him that this is quite likely. I know that all the regulations (for brick extensions) require such an overlap, I am equally certain that in many cases this does not happen for the reason above.
Is there a reasonable, tanking type seal, which could be used to solve the problem, and to avoid damaging the existing DPC. The builder just intends to lap the membrane up the wall, but clearly water pressures will eventually force damp up into the skirting board/plasterboard.
Thanks in anticipation
