I'm about to add a 3m x 4m conservatory on to the back of my house which requires a 600mm high dwarf wall. Can anyone abswer the following questions for me?
1. Will 650mm foundations be OK or should I go down 1m?
2. Should I finish the foundations below the existing ground level and build up with 2 courses of engineering bricks and will these be fine as a damp course or should I add a DPM, if so where should it go.
3. Must the finished floor height be level with the existing damp course? If it can be lower, does it matter how much?
4. I've been advised that the floor should be 75mm hard core then 100mm concrete with a screed on top. Is this OK and where should the DPM go?
5. If I decide to put in under-floor heating, I'm told I should allow for 50mm of ploystyrene installation on top of the concrete and then a 75mm screed on top of the ploystyrene. Is this OK and what material should the floor screed be.
I know I really should call in a builder but I fancy having a go myself, just for the experience.
Thanks in advance.
Thanks in advance.
