Ive been reading up on the internet about foundations for a conservatory.
Nearly all the information i have found tells you to dig down and put the foundations deep in the ground with a wall on top to support the structure.
However i have found a diy conservatory website which has a plan to only dig down 150mm below ground level. Have i misunderstood the diagram or does this sound correct. It sounds an easy way of doing it.
Here is the website and it is example no 2 here
