Suffering the usual conservatory problems (just moved into a new home that has one), too hot in summer, too cold in winter.
4x3.5m roof (4 x 1m x 3.5m panels)
Tiled option - too expensive! £5k
Thermotec - too expensive £3k
Ecoroofpanels - Max 3m long, so no good
25mm Poly with inserts £1200
Also looked at DIY approach using foil or kingspan type boards but not sure I want to give myself that headache as I know moisture can be an issue...
Would 25mm poly with inserts actually do the job, perhaps not as good as some of the others, but cant really stretch to £3k...
