conservatory lights
18 Aug 2007
Sheffield
Would anyone like to advise me on the easiest legal way to wire a switched ceiling light into a conservatory.
Already wired two sockets on a fused spur from another socket on the ring main.
would it be best if I tapped in to a light radial or added another spur?
Your easiest way would be to fit another FCU and either use that to switch the light, or fit a seperate light switch - perfectly acceptable.
If it is easy to pick up off a lighting circuit then I would do that as then you are keeping all your lighting on actual lighting circuits.
When you say fit another fcu do you mean to the same socket as the spur sockets are wired too?
What if I wired a fcu from the original fcu?
