Just had a radiator put into thye conservatory.
During a kitchen re-fit we discovered that what we thought was an electric fan heater at floor level under the oven was actually plumbed into the CH. As we had an intention of putting a rad in the conservatory this provided an ideal opportunity to use the existing pipe work to run new pipes into the conservatory. This we did with 15mm pipes into a new chrome rad. Everything bled and seems there is no air in the new pipework but rad won't get hot.
I do not know what the existing pipework to the heater was connected to but suspect that as the utility room radiator is right behind where the pipework is that it is connected to that.
Old heater was connected to house pipework with flexible pipes with stop valves which we used to plumb the new pipes into, the valves are on.
Any suggestions?
Any suggestions?
