Conservatory removal and potential damp problems
17 Aug 2012
Tyne and Wear
Hi I'm taking my conservatory down soon (23 years and past it) to creat on open outside sitting area.
The concrete floor within in it, is at the same level as my internal wooden floor, both are separated by a sliding patio door. My plan is to leave the concrete floor as it is, which would be either tiled or astro turfed to make the open patio area.
I'm concerned that once the conservatory is removed, when it rains I could have rising damp in this area.
My thoughts at the moment are to cut a channel into the concrete floor and insert a drainage channel between the external house wall and concrete floor.
Can anyone offer any advice please
Cheers
There's quite a few other potential problems. Sockets and electrics, gypsum plaster, etc.
I suggest you first get an electrician in to make your electrics safe for the external environment, then remove the conservatory, including floor tiles, and come back with your question, and photos of your potential damp problem.
You're going to have to remove any gypsum plaster from the outside walls.
Cheers for the reply
Regards electrics they'll be sorted prior to taking down the conservatory.
The plastering will also be removed and the walls either rendered or a suitable facing put on.
As for devaluing the property by removing the conservatory, it's been up 23 years, the UPVC frame, roof and glazed units are well past their best.
We have considered rebuilding but realise that when it's sunny it's to hot to sit in and when cold pointless without wasting money on heating. We tend to take chairs outside when the weather's hot so thought what's the point of building a new conservatory. Added to that is the cost of rebuilding a conservatory or even a proper room.
A linear drain paralel to the patio doors will be fine.
You wont get rising damp.
You're not removing a room! You're removing a plastic frame attached to your house.
