Hi, and thanks for reading
Im currently thinking about installing a floating ceiling in my conservatory as temperature is an issue.
A concern of mine is if I do this and pack the void with insulation then it needs to breathe as condensation will build up in a big way. There are two vents already that a placed where the roof attached to the window but these are only 400mm long and are not fully opened for the 400mm and are both placed opposite each other at the bottom of the conservatory, will this be enough for a conservatory that measures 5mtrs x 3mtrs?? If not what else can be done without removing the roof!!!!?!???
