Hi all I've read a few threads on this but none seem cover all my questions.
Basically I have a 5m x 3m flat roof conservatory and usual story baking in the summer freezing in the winter.
So I looked into insulating the roof and found companies that do this by putting up insulation and plasterboarding over. However I don't feel comfortable with all that weight from the roof.
I also saw one which seemed to do the same thing but used that upvc cladding instead of plasterboard and it actually seemed to look quite nice surprisingly. But am I right in this can you use this stuff to hold the insulation up?
I think the insulation to use is called "super quilt" and is 40mm thick foil insulation.
So do I just fix some wooden battens to the frame fix the insulation up then screw the cladding on top?
Do I need to have an air gap between the insulation and roof?
Really would appreciate any help and advice
