Conservatory suspended ceiling advice
31 Mar 2016
Hi all, I'm thinking of creating a false ceiling in our conservatory because my partner will be using it for her dog grooming business. It doesn't need to look pretty, just do a job. I plan on putting 4x2's across the 3m span.
I will then clad the ceiling with some upvc - either hollow t&g or plain panels.
However I'm a bit stuck on the insulation. I'm thinking of either going for multifoil insulation or PIR boards. Will put a vapour barrier on the room side as well before the cladding.
A concern I have is that the roof void will be become dangerously hot in the summer. Will the foil backed PIR or multifoil help reflect the heat away?
I know this isn't standard, and I'm not expecting miraculous results.
I've posted quite a few times in the past about and had no replies so would really appreciate some help!
Read more: https://www.diynot.com/diy/threads/...-in-conservatory-advice.538154/#ixzz6qiw5Piki
What’s the roof made of? Glass will be ok but experimented with black insulation below a plastic roof and extra heat melted the roof panels .Maybe used rock wool as it’s not reflective.
Hi, thanks for the reply. The roof is polycarbonate, approx 15years old. Would a foil like superquilt work help in that it can reflect the suns heat/rays?
