I am trying to reduce the summer time temperature in my Edwardian Conservatory. There appear to be lots of solutions but I am struggling to find reviews to determine the best/best value option.
My conservatory is 5.5 meters x 4 meters with a standard 25mm poly carbonate roof.
The summer temp is unbearable - and it is damaging items that I keep in the conservatory. I want to keep the temp below 90 degrees at all times.
The first option I looked at were the various companies who insulate the inside of your existing roof and then board over before skimming. This sounds a reasonable approach but my current roof is 10 years old and looking tired. I figured it might not be worth spending a couple of thousand on this only to have the outer roof fail because it is reaching the end of its life. That aside - anyone tried this approach - any views?
The second option was the Guardian roof system. This replaces your roof with a light weight solid roof. This looks an good option but very expensive - I have had quotes between 7.5K and 12k! I don't want to spend this kind of money unless I know that it's a great option - anyone actually had this fitted? Is it worth that cost? I like the fact that it should reduce rain noise and keep the noise from stereo annoying the neighbours.
The third option to to buy solar control inserts (e.g. Polycool) and insert them into the existing roof. These are still quite expensive and the cost for my sized conservatory will be nearly £1,000 just for the inserts. Anyone able to comment on just how effective they are?
I am also looking at a fourth option - a new conservatory roof using 35mm Corotherm Heatguard Fivewall Polycarbonate. I can get a new roof with heatguard installed for around 2.5K. This is actually sounding like the best value but again - anyone able to comment on effective these are? Will they keep my room below 90 degrees? Are they are good as solar inserts? If you were buidling a polcarb roof from scratch are these the most effective product you can choose?
Much appreciate your views/help/suggestions....
Jim
Jim
