I'm planning on building a lean to conservatory, I want to make side walls to be solid as there is no way i can do any maintenance if i were to use glass. As for the roof it would be a solid cold deck roof with 2 skylights. The front would have dwarf walls up to 600mm and the rest glass.
I don't plan open up the existing house so it would be separated. Would i need building control or not and is this approved as a conservatory?
