Am using joint compound on taped joints. (Managed to get two coats on then had to leave it for a week due to other commitments.)
With the second coat, having filled the joint, when I went along the joint with a knife, the compound pulled on itself, leaving a very rough finish.
I suspect the mix was too dry or too wet. Or I had the knife at a bad angle.
Any suggestions?
Any suggestions?
