constructing a warm flat roof
8 Mar 2007
hi im doing my flat roof im gonna insulate it using kingspan so ive got to deck it first put down my kingspan then install my 18mm board on top what i cant see is how do you bolt the top board through the kingspan any help in this matter much appreciated thanks in advance
kingspan make a ply bonded insulation deck that fixes straight to the joists.
no need to buy two separate products.
you will need to use the 97mm thick version if you are going to adhere to building reg's.
