Under the new (well 2008) PD regs you can build a dorma upto 40m3 onto a mid-terrace.
I've always constructed Dormer's using the following :-
OUTSIDE
Slate
Horz. Batten (2" x 1")
Breathable Membrane
Vertical Batten(2" x 1")
18mm WBP Ply
2"x4" Stud wall (With Celotex between and over studs)
Vapour Barrier
Plasterboard
Plaster
INSIDE
I've seen a few builders remove the vertical batten (not too concerned about that) BUT, instead of using WBP Ply they are using OSB3.
Surely this is not fit for purpose as it's not a "structural" sheet material.
I know the last Dormer I did BC were insistent on using WBP Ply.
Would appreciate your comments on the substation of WBP Ply for OSB3.
Paul.
OUTSIDE
Slate
Breathable Membrane
18mm WBP Ply
Vapour Barrier
Plasterboard
Plaster
INSIDE
Paul.
