I have to resite a consumer unit from inside position to the outside wall directly opposite it. I want to fit a recessed waterproof box into the outer skin and fit the CCU into the box. I will be using a Wylex 9 way split load for the CCU. The outside wall is currently is currently covered with a semi permanant roof, however it might not stay that way.
I am looking for a waterproof box that I could use. I assume I could use a standard recessed meter box, but is there anything smaller? What is your reading on the regs as far as enclosing the CCU in this way?
