I will shortly be moving into a new house which has an old consumer unit next to the meter on a wall in the integral garage. The only way into the garage is through the front garage door - there is no access from inside the house.
On the other side of this wall is a large under-stairs cupboard (with a proper 6ft door) and I was thinking about having a new CU relocated to this cupboard.
EDIT: I tell a lie - the door is about 4ft high!
I would have a DP 100A isolating switch in the garage close to the meter, and then run tails from this through the wall straight into the back of the CU. The tails would be no longer than 3m.
I prefer the CU to be easily accessible from inside the house, but not on-show in a room. So does this sound reasonable? Or would you recommend just keeping the CU where it is?
Thanks in advance for your advice and criticism! I don't need the Part P preambles - I, or an electrician, will comply.
