Right guys, time to replace my Consumer Unit, But im after some advice.
Currently Its a Fused / Wired consumer Unit, and i want to change it to a more modern MCB Type.
Ive not looked into the Fused Comsumer yet, but i can tell you it has 6 Fuses as follows:
1 x (Green) that has a Mcb pluged into it 45 Amp (Labled COOKER)
2 x (White) 5 Amp (Labled LIGHTS)
2 x (Red) 30 Amp (Labled Sockets)
1 x (Blue) Unknown amp (Labled Emergence Heater)
Also the Standard ON /OFF Switch.
Ive Noticed nothing is labled Shower, and we have an electric shower, so where that goes i will need to check. This will be possble as im going ot be fitting a new shower soon, hence the reason i want to do the consumer Unit too.
Currently Im thinking along the lines of :
Source from Meter to an RCBO
RCBO to Consumer Unit, then wire accordingly.
32 Amp RCB for Mains
6 Amp for Lights
The cooker , Shower and Emergance heater Id like advice on what to use please????
Im also thinking of running 2 x 2.5mm and 2 x 1.5mm from the new consumer upto the loft, (Not connected to anything) In the hope that when we Extend the house back, We can use these for the Mains and lighting supply. At that time Ill conect them to seperate mcbs, Is this a good idea?
One last thing, Any Advice on Earthings would be nice, Theres an earth to what i think is sheld at the source, but our water into the house is plastic, we dont have gas either, so am i right in thinking all earths need to link to the source earth, and the water pipes internaly should be bonded and linked to the source earth too???
REALLY SORRY FOR WAFLING ON HERE GUYS, BUT WOULD BE NICE TO HAVE A BIT OF HELP ON THIS ONE....
2 more things... the Source fuse seal is already broken, so a nice pair of pliers should help that come out, and lastly, once ive done it all, i will be getting a Propper sparks to come and sign it all off.... I think
Many Thanks In Advance
MA
6 Amp for Lights
MA
