- Joined
- 7 Jan 2004
- Messages
- 1
- Reaction score
- 0
- Country
I have recently had an extension built & kitchen conversion etc & had one extra ring main added in 2.5mm^2 cable on a 32 amp breaker and a lighting circuit in 1.5mm^2 on a 6 amp breaker.
The sockets are only used for 2 lamps at 60 watts and a electrical fire which operates at 2.5kW up to 3kW and there are only 2 lights on the new circuit at 60 watts.
When the Electrical Fire is in use the consumer unit makes a buzzing sound but not from the new MCB's but the main 100 Amp breaker.
No MCB's have tripped and no cables have been melted etc.
The electrician involved has said most units do this when demand is high!
I have calculated that with most appliances on at the same time I don't get anywhere near 60 Amps
Is this true or should I get his ass back on the job?
Any advise would be greatly appreciated.
