consumer unit
6 Mar 2007
Essex
Hi
I have 2 consumer units one for the house and one for my storage heaters.
Would it be possible to have them both put into one C/U
I would like to switch off the heaters separately in the summer (when we have one lol ) so is there any C/U with 2 main switches ?
Since the storage is via a E7 type meter and has it's own tails from the supplier, I'm sure you can't.
A CU has a single service in, so unless you want to run your storage heaters via normal (non cheap) supply, the answer is 'no'
:D
you can get dual tariff boards, either with an RCD and isolator switch or two switches, if you need RCD protected circuits and non RCD protected circuits just get the type with two main switches and use RCBOs instead of MCBs for those particular circuits
Dual Tariff board
Wylex NHIIX6604 Insulated dual tariff consumer unit 6/6
Dual Tariff 100A Main Switch And 100a 30mA RCD
Dual Tariff 100A Main Switch And 100a Main S
MK make a CU with 3 switch
disconnectors for use in multi-tariff heating
applications, one of which could be replaced with an RCD if you need a split load formation for the non heating side
K5656s
INSULATED CONSUMER UNIT
ONE 63A SWITCH DISCONNECTOR
TWO 100A SWITCH DISCONNECTORS
AND 3 INTEGRAL NEUTRAL BARS
ACCEPTS A FURTHER 10
ONE MODULE PRODUCTS
(SURFACE)
Dual tariff boards are quite expensive and less simple.
1) Why do you want to do it?
2) Does all your electricity go onto cheap rate at night, or does the additional circuit get switched on at night and off during the day?
3) You have storage heaters :( so are you at home during the day?
4) If you wish to switch off your storage heaters in summer, why don't you just use the main switch on the Storage Heater CU?
GTD
Well I learn't something new today :oops:
Still, I'm not sure I'd ever promote the product :rolleyes:
