The electrical installation in my wk end home failed the domestic installation inspection on the following points
The consumer unit which has a isolator switch and MCBs is mounted on a wooden frame(looks like original equip) which holds it off the wall by approx 20mm
One of the ring mains is broken to the effect that it's now 2 radials
I've been told that I should replace the consumer unit so that it is flush with the wall, and either find the break in the ring and fix, or put them on seperate 20A radials
I would like to know if the wood backing frame should be a failure, and if I replace the board with a new larger one and the tails of the cables are now too short, can I extend them within the consumer unit by using connector blocks?
