Hi, Could someone tell me if I have a problem with my consumer unit. When a light bulb blows it usually trips the fuse, but today the main RCD switch tripped which turned all the power off, about a minute later whilst I was looking at the fuses(before switching the RCD back on) there was a flash of light from the box and the light fuse tripped, I switched both the fuse and the RCD back on and all worked OK ( just the light blub needed changing) The question I have is, is this a problem?
