Hi all.
I am building a closet with hardwood ply. I had intended to sand and finish the ply with osmo oil and leave it at that because it's quite attractive stuff, but my wife has overruled me and wants an oak-like finish, using contact paper. Seems sensible enough, but any advice on whether it will adhere to plywood properly? And is there anything I can do to improve my chances? I did a test on the unfinished plywood before I sanded and i struggled to get a good finish in particular at the edges, and every little imperfection in the surface shows up.
I put filler across the exposed edges and then sanded all surfaces to 180 grit and knocked off the sharp corners, but I've put no finish on the surface yet. I could still put the osmo on but it's expensive stuff so don't want to waste it if it's not necessary or a cheaper option would work. Stuff I've got in the shed which might work includes:
Osmo door oil
Decorator's varnish
SBR primer
Mapei primer G (likely well past its use by date)
PVA
Dulux water-based primer/undercoat
Any thoughts would be welcome. The other alternative is to line the whole thing again with hardboard, shiny-side out, but I'd rather avoid that if possible.
Osmo door oil
Decorator's varnish
SBR primer
PVA
