I'm wiring 2 lighting circuits through a contactor to be controlled by a single switch. Both circuits include an emergency light. Should considerations be made for emergency lighting related to a contactor/coil failure as the coil feed will be on a separate circuit. Initially I was going to use normally open contactors but am now considering normally closed so if the contactor failed the lights would be on. Or is the emergency lighting only required to operate on a total loss of power?
