Just wiring up a lighting circuit (line and neutral connected at board) and everything was going well with my continuity tester - hearing the beeps and moving on ... but I wanted to ask a question, because something looks suspect when I started testing my two way light switch. Here's the set up, and if you can help me, I'd appreciate it.
1. I've done the lights through to the last one, and get 1.15 ohms (Testing L/N, and L/N connected at board).
2. I have JB to spur off from one of the lights closer to the CU in the circuit, then have a normal T&E going to one switch and 3 Core and Earth connecting that switch to a second switch. The switches operate two light in parallel.
3. Now, when I directly connect the T&E switch using a connector block (and not connecting the switches together) just to test that both lights come on, I get 0.62 ohms from Light 1, and 0.73 ohms from Light 2 (running to the CU). This makes sense, as light 2 is a little further away.
4. Now I disconnect the connector block to wire up the 3 core to connect the two switches, and test again. This time I get 2.01 ohms and 2.17 ohms from Light 1, and 2.10 ohms and 2.13 ohms from Light 2 (closing switch one and opening switch two and vice versa). Now given that a lot more cabling down stream to the furthest ceiling rose only gets me just over 1 ohm, this seems far too high, so ...
5 ... I disconnect the two switches to test continuity down the 3 Core. I directly connect the three cores at one switch together, and test between pairs of wires at the other switch, and get 0.22 ohms (for each of the combination of pairs).
6. In summary, the resistance down the 3 cores is 0.22 ohms, the resistance using a standard 2 core switch to operate the lights gets me 0.62 and 0.73 ohms, the furthest ceiling rose gets 1.15 ohms, but when I try to connect the 3 core it jumps up to over 2 ohms. The distance of the 3 core is about 5 metres. The connection of the 3 cores to each switch is the same and matched to COM / L1 / L2. The connection of the 2 core goes to L1 / L2.
7. In my mind, I am happy with the resistance down the three cores by themselves, down the single 2 core switch connected by itself, my connections are tight - I've checked them over and over ... does it just leave the problem down to a dodgy switch, or am I missing something?
