Hello,
I was wondering if you could help me with my problem.
I have and S plan system - fully pumped HW and CH. Main problem is that the boiler and pump will not respond to the controller. Doesn't matter what buttons I press the system stays on. The only way to turn the system off is at the fused switch.
Components:-
Baxi Wm 532 boiler
Switchmaster 805 controller
Satchwell room thermostat - TLX 2356
HW tank thermostat
Sunvic SM5302 heating valve/actuator energise open/close - 2 port
Sunvic spring return hot water valve/actuator - 2 port.
Now, the British Gas engineer that came to look at the system, so as to check for having a service agreement, reckoned that I had a sticky valve. He took HW actuator off. Heating system was unaffected. Just had to manually turn valve for HW. (He also said boiler was too old to take on a service agreement!!)
So, following his advice (or as I interpreted it) I duly purchased not one, but two valve bodies which I have replaced and I have reconnected the existing actuators.
After reconnecting everything the system will not switch off. It seemed to me like the HW actuator was working fine previously but the CH actuator was naff (?). So I have repalced the CH actuator today thinking all would be well. No it is not. Still won't respond to controller.
The HW actuator does respond to the tank thermostat though.
The boiler and pump seem to be getting a live feed from somewhere and ignoring the controller. Could it be the HW actuator afterall????
I have cleaned room thermostat, checked all actuator wiring etc, all seems well.
I'm baffled as to what could have changed. Seems almost like I need to hit a "reset" button, but there isn't one.
Any ideas???
Pete
Components:-
Baxi Wm 532 boiler
HW tank thermostat
Any ideas???
Pete
