- Joined
- 5 Jan 2016
- Messages
- 6
- Reaction score
- 0
- Country
I have an oil fired pumped CH system that has worked fine for years. Recently the system has stopped reacting to boost or advance requests on the Grasslin Towerchron QE2 controller but still is fine in normal timed mode. I say stopped but sometimes after a very variable time the system does react when on boost or advance albeit seemingly having a mind of its own!
I've tried what I think are the obvious, tap stuck pump with hammer, similar to various valves, waggle wires etc. Sometimes this starts the boiler but not usually- nothing is consistent!!!
This morning I removed the control box and sprayed with contact cleaner to no avail. Set on boost nothing happened then maybe 20 minutes into a one hour boost (indeed as I write) suddenly the system fires up.
Once this has happened it will go back to normal timed mode and be OK.
Any ideas anyone???
Cheers Pete Slawson
Any ideas anyone???
Cheers Pete Slawson
