I have the old type of off-peak supply (ie one meter for standard supply and a separate one for off-peak supply overnight.)
Originally the off-peak was used for storage heaters which are no longer present, and it is now used soley (at present) for an immersion heater.
A year or so ago I had a Horstmann BX controller fitted which is wired between the supply and immersion. This automatically turns on the immersion overnight using a feed from the off-peak Cu, but is also wired to the standard supply CU so a 'boost' switch allows top up any time during the day.
The BX is wired directly back to the CU's and there are no other electrics on the circuits - just the immersion heater.
Recently I noticed that there were some 'brown stains' on the front of the controller, and on investigation discovered that the box was getting very warm on the front (there are two seperate stains - one in front of the internal relay, and one in front of an internal control unit). None of the connecting cable gets warm.
I spoke to Horstmann who said this was not normal for the unit and it sounded as if there was something in the circuit drawing too much current.
As the immersion is the only item in the circuit - could this be the problem, and if so what fault could have developed to cause this??
I would say that I have a second BX unit, and when I swapped them over the second unit was getting warm too.
