I'm looking at a system where the DHW is heated via gravity circulation from a gas fired AGA, although there is a conventional gas boiler supplying CH system. The problem I'm anticipating is that because AGAs are running continuously, there doesn't seem to be a straightforward way of controlling the DHW temperature since the cylinder acts as a kind of heat sink.
This is a potential problem because if hot water temperatures get excessive, the design parameters of various components (pumps, shower valves, taps, etc.) will be exceeded and damage (reduced life) may result. Furthermore scale formation increases greatly above 60C, causing further problems. I'm not that familiar with AGAs, so I would appreciate advice on the following points.
Firstly is there any way of limiting DHW temp., say with a motorised valve, without having to provide an alternative heat sink (say radiator)? Alternatively, is it feasible to drain the AGA circuit and run the AGA "dry", so relegating the AGA to being just a cooker and run HW off the boiler?
