I have CH system with pumped CH and gravity HW. It consists of
Ideal Mexico boiler
V4043H 2 port valve
Lamdis & Gyr RWB2 controller
Pump
The CH has no room thermostat or hot water thermostat and allows for hot water only or hot water and CH.
!. Can the system be changed to have separate control of the CH and hot water
2. Is it possible to be able to control the CH by using a programmable thermostat.
3. Is it advisable/possible for the boiler to be automatically turned off if both the HW and house have reached the desired temperature according to the thermostats
4. Should the pump carrying on running for a short time when the boiler is switched off due to the room thermostat reaching the required temperatue
5. Is it best to have a new CH controller and if so can you recommend one
6. Can you recommend a medium priced programmable thermostat
7. Have you any other recommendations
Tony
Ideal Mexico boiler
V4043H 2 port valve
Pump
Tony
