My son has recently moved house;…it’s a 3 bed detached house built in 2001. It has an ‘Ideal’ ‘combi’ gas boiler that was fitted less than 2 years ago.
Just got a few questions for you guys regarding the use of a ‘room stat’ to control the temperature of the entire house.
The room-stat is in the hallway/stair well ;…the radiator in that area does not have a TRV. In fact none of the radiators in the entire house have a TRV fitted.
The hallway needs to be kept overly warm otherwise the boiler shuts down and not enough heat is delivered to the rest of the house;…that in itself is very inefficient because the ‘hallway’ is not really a living space and there is no need for it to be so warm.
My son lives on his own, but uses one of his extra bedrooms as an office a couple of times a week.
At the moment all his radiators are heating up and cooling down at the whim of the hallway ‘room stat’ which is not really what he needs. Apart from the main bedroom and bathroom, which he’d like to keep at constant/comfortable temperature, he has 2 other bedrooms that can be kept at a lower temperature most of the time, but he’d like the option of raising the temperature when the rooms are actually in use.
At the moment the heating is ‘all or nothing’ in every room,…even when he doesn’t need it;…even his girlfriend has commented that the upstairs is either too hot or too cold.
The ‘room stat’ is functioning perfectly and it’s controlling the boiler properly;…I’ve checked the displayed temperatures with an industrial thermometer and it’s just about spot-on.
Does he need TRVs fitting?....does the room-stat need re-siting?...do the radiators need balancing or something like that???
Any suggestions as to how things can be improved will be gratefully received?
Thanks.
Thanks.
